  2. Nissan Leaf Powertrain
  3. On Board Charger
  4. DC Charging a later gen Chademo or CCS2
Scheduled Pinned Locked Moved On Board Charger
9 Posts 6 Posters 850 Views 2 Watching
    Land Rover SIII
    Why do the later motor stacks not charge on Chademo?
    Has anyone found a work around or a way of charging with CCS2?
      Not very elegant, but you can use the conversion / adaptors that Leaf owners use. Not cheap though. Thereโ€™s a few versions around. I know in the UK, thereโ€™s a Leaf forum that has had good results with the EV Boy type.
      • R Offline
        R Offline
        reridesev
        I've heard the BMS messaging is more complex. @isak has been working on it a while, not sure of where it currently stands or if that's really the issue
        • T Offline
          T Offline
          Tomas
          In the later stacks the logic for Chademo was moved from the pdm to the cars vcu so it won't work
            Land Rover SIII
            wrote on last edited by Land Rover SIII
            #5
            Does anyone know if I can run the 40kwh leaf battery motor and inverter with an earlier PMD to get chademo charging? @isak ๐Ÿ™‚
            S 1 Reply Last reply
            • L Land Rover SIII
              S Offline
              S Offline
              Saabel
              wrote last edited by
              #6
              @Land-Rover-SIII said in DC Charging a later gen Chademo or CCS2:
              YES
              D 1 Reply Last reply
              • S Saabel
                YES
                D Offline
                D Offline
                DTL
                #7
                @Saabel Are you saying you can run a 200hp motor with an 100hp PDM to get DC CHAdeMO charging? Have you done this? I am trying to decide if I want to go with the 100HP to get DC charging or go with the 200HP and only have AC charging. Thanks
                • S Offline
                  S Offline
                  Saabel
                  #8
                  yes, i am running my old 120 hp 3.3 kw PDM unit with full Chademo and new 210 hp inverter and motor , you need to fix a little in the harness, not exactly the same connectors , but not that much. next step I have a 7 kw Old unit ( a little rare here in sweden ) ready to go in this winter for "good to have". --> So use old wiring for PDM and new wiring for inverter. it is described by Isak in the wiring but maybe not super easy to get initally https://docs.google.com/document/d/1-MKLxoBYLWn_ywoVPNeDJRtGWCbPHTkntxF0TH2A_gs/edit?tab=t.0
                  • S Offline
                    S Offline
                    Saabel
                    wrote last edited by Saabel
                    #9
                    but maybe start here https://docs.google.com/document/d/1VLLGGjotzOc6-GGN6rD6Fa7jOnej7dBHD3q2Gkn0Kgk/edit?tab=t.0
                    page 9 Inverter
                    So round or square connector fix is needed solder some cables and go
