79 Posts 4 Posters 4.2k Views 2 Watching
    BMS with all the harnesses attached. Not sure if all these connections are necessary for our build but we're going with it until we hear otherwise. Anyone want to comment on what's necessary and not? I'm not sure how to invoke the "@isak" link for his response. It would be great if someone could help me with that.
    @leshall89 All the BMS connectors are necessary except the ones going to the relay that controls the resistive heaters that sit on the cells (not all leaf packs come with resistive heaters). It's the cables that go from the BMS to a rectangular black box. Temperature sensor cables connector and the 12V and CAN connector and the rest of the balancing wires are all needed for the BMS to not throw a fit πŸ™‚
    • E Offline
      E Offline
      Emanuel
      Really nice build! Well done. Thanks for all the good info.
      • E Emanuel
        @Emanuel Thank you, it's been a lot of fun!
          @isak When you speak of resistive heaters, is this what you mean? Can I remove these things along with the wiring?
          PXL_20260311_172809972.jpg image url)
              All the wiring connections have been temporarily made and the quick release battery cable ends have been attached. It's now time to connect the Resolve-EV controller and wiring harness and see if we can turn the electric motor!
                Hooked everything up as directed, no motor turn, doesn't seem to go into drive mode from neutral as shown on the OLED screen. Waiting for @isak response to help me troubleshoot unless anyone else is able to help.
                    It’s not normal to get N206c error message on the display. Try working out what that means.
                      @leshall89 said in 1966 Jeep CJ5 4x4, GE Jeep!:
                      Yeah that's exactly what I mean, you can remove them
                        @ianlighting Try working out what that means? Should I go back to college and get an electrical engineering degree?
                          you can read what the error codes mean the Owners manual: https://resolve-ev.com/pdfs/owners_manual.pdf
                            @isak Now that I know what is shown on the OLED is an error code...this code is "Caution lamp and Charging stop" From the Owners Manual: These are all errors directly from the Nissan Leaf BMS, they are quite explanatory and should also be corrected immediately. A good solution to locate the error is to use Leafspy
                            and look for the errors the BMS experiences. One cause for the caution lamp and charge
                            stop error could be a disconnected BMS balancing wire. This will cause the bms to not allow
                            charging of the battery and limit the motor to 4.5kW of power.
                            It is recommended to use a bluetooth dongle and to connect Leafspy to your car for specific
                            diagnostics and to see the health of your battery.
                            The LELink bluetooth OBD dongle came with my kit. Doesn't look like I can access it because I don't own an Apple product.
                            Is Leafspy an app or another piece of hardware?
                                This is the document that came with the LELink dongle with my kit. There is nothing in it that says to connect to Leafspy.
                                    Leafspy shows no DTC codes. Now the project is stalled until someone can help me diagnose what needs to be corrected.
                                      Posting the multimeter readings from all 3 battery packs.
                                        And here's the OLED display.
                                          As you can read in the Owners manual linked here: https://resolve-ev.com/pdfs/owners_manual.pdf
                                          This is a "warning light" signal from the BMS I would recommend updating the Resolve controller to the latest software update here: https://resolve-ev.com/update
                                          If that does not solve it I would try to troubleshoot if something is connected wrong to or from the BMS
                                          Regards
                                          Isak
