  3. 1962 Chevrolet Corvair Van
15 Posts 2 Posters 1.4k Views 1 Watching
  • T Offline
    T Offline
    trevorb24
    • T Offline
      T Offline
      trevorb24
      Adapter plate prototype mounted to the Corvair bell housing and together with the Leaf motor...fitment looks good.
      • T Offline
        T Offline
        trevorb24
        • T Offline
          T Offline
          trevorb24
          Stock loaded up in a CNC mill to machine the adapter
          • T Offline
            T Offline
            trevorb24
            wrote on last edited by trevorb24
            #9
            • T Offline
              T Offline
              trevorb24
              In three different setups the profiling, drilling, pocket milling, and tapping for both sides was complete. After machining, two 10mm locator pins were pressed into circular pockets made in the plate. These are the pins that will fit into the Leaf motor face. Similarly, pockets were milled on the Corvair side to make a transition fit with the locator pins in the bell housing.
              • C Offline
                C Offline
                colincotton
                Very nice!
                • T Offline
                  T Offline
                  trevorb24
                  wrote last edited by
                  #12
                  We used a pre-machined EM57 coupler and combined it with the cut out center of the Corvair's clutch to create a direct drive connection between the motor and the original transmission input shaft.
                  • T Offline
                    T Offline
                    trevorb24
                    #13
                    Turning down the clutch center.
                    • T Offline
                      T Offline
                      trevorb24
                      #14
                      Turning down the spline coupler.
                      • T Offline
                        T Offline
                        trevorb24
                        #15
                        We then pressed the two ends together and welded along the seam.
