DC Charging a later gen Chademo or CCS2
Why do the later motor stacks not charge on Chademo?
Has anyone found a work around or a way of charging with CCS2?
Not very elegant, but you can use the conversion / adaptors that Leaf owners use. Not cheap though. Thereโs a few versions around. I know in the UK, thereโs a Leaf forum that has had good results with the EV Boy type.
Does anyone know if I can run the 40kwh leaf battery motor and inverter with an earlier PMD to get chademo charging? @isak
@Land-Rover-SIII said in DC Charging a later gen Chademo or CCS2:
YES
YES
yes, i am running my old 120 hp 3.3 kw PDM unit with full Chademo and new 210 hp inverter and motor , you need to fix a little in the harness, not exactly the same connectors , but not that much. next step I have a 7 kw Old unit ( a little rare here in sweden ) ready to go in this winter for "good to have". --> So use old wiring for PDM and new wiring for inverter. it is described by Isak in the wiring but maybe not super easy to get initally https://docs.google.com/document/d/1-MKLxoBYLWn_ywoVPNeDJRtGWCbPHTkntxF0TH2A_gs/edit?tab=t.0
but maybe start here https://docs.google.com/document/d/1VLLGGjotzOc6-GGN6rD6Fa7jOnej7dBHD3q2Gkn0Kgk/edit?tab=t.0
page 9 InverterSo round or square connector fix is needed solder some cables and go
Hello! It looks like you're interested in this conversation, but you don't have an account yet.
Getting fed up of having to scroll through the same posts each visit? When you register for an account, you'll always come back to exactly where you were before, and choose to be notified of new replies (either via email, or push notification). You'll also be able to save bookmarks and upvote posts to show your appreciation to other community members.
With your input, this post could be even better ๐
Register Login
