      Leafspy shows no DTC codes. Now the project is stalled until someone can help me diagnose what needs to be corrected.
        Posting the multimeter readings from all 3 battery packs.
          And here's the OLED display.
            As you can read in the Owners manual linked here: https://resolve-ev.com/pdfs/owners_manual.pdf
            This is a "warning light" signal from the BMS I would recommend updating the Resolve controller to the latest software update here: https://resolve-ev.com/update
            If that does not solve it I would try to troubleshoot if something is connected wrong to or from the BMS
            Regards
            Isak
              Regards
              Isak
              @isak I was able to update the software, although I tried updating to 3.7, Console shows 3.5. Data doesn't appear to show anything even with connection. Connecting Ignition to 12v causes a "waiting for data" message that doesn't end.
                Not sure how BMS could be connected wrong considering all connections have only one specific port they fit into the BMS.
                  @isak Sure would be nice to get some feedback for all the emails I've sent you trying to figure out the problem why this won't work...
                    I just realized Leafspy isn't connecting with the LeLink dongle so the picture 20 days ago isn't actually showing anything from my system since the lower right hand corner isn't green. Still can't get Leafspy to connect to LeLink, I think this might actually be a problem with the Resolve system...what do you think @isak?
                      I would recommend being concise in your emails and not sending 14 emails in the span of 2h. It does not really make it easier for me to help you. To focus on what I think the issue is and as I wrote to you via email. The last console log you sent showed that the leaf BMS think's the packs voltage is 511V which i suspect is due to the voltage sensor is disconnected or not functioning properly. I would focus on solving that
                        Ended up buying a whole other battery pack from a newer Leaf, 40kwh. No more error code, but motor won't spin.
                          Found the culprit! This short connector had resistance in 2 of the 8 wires. I swapped it for another 8 wire cable and voila, spinning motor!!!
                            And now we can finish putting it all together. Happy days!
                                      Water pump installed on front of motor, all hoses installed.
                                        @isak, I have a 52 second video of the GE Jeep maiden voyage I'd like to post (16.5MB). Is this possible?
                                          Been driving my Jeep around now for a couple months, super fun. Drive system is working great. Still in the testing phase for all systems but it seems to be up to the task. Appears to have about 80 miles of range. Haven't tested the 4x4 system yet, soon.
