  3. 1971 Triumph Spitfire
9 Posts 2 Posters 564 Views 1 Watching
  • S Offline
    S Offline
    steveo
    Getting there slowly....
    Cars as purchased
    First paint ready for mechanicals.
    Leaf motor bolted to original Overdrive gearbox means I'll be able to run in 3rd or 4th all the time with overdrive being selected where needed (although not in reverse - overdrives have a habit of exploding when going backwards!). Adaptor plate still to be trimmed.
    Offering it up. Little clearance but does fit using original gearbox / engine mounts.
    Inverter charger in using original radiator mounting brackets.
    First batteries fitted.
    Rear batteries shoehorned in.
    First test drive - it does actually move under it's own steam.
    Further progress - it does all fit...
    Classic mini radiator with electric fan appears to offer more than enough cooling
    (/assets/uploads/files/1773224542032-it-does-fit-2.jpg) It does fit 2.5.jpg it does fit 3.jpg it does fit 4.jpg it does fit 5.jpg it does fit 6.jpg
    Dashboard has relevant switches etc. Overdrive engaged warning light will hopefully remind me not to select reverse if it's engaged.
    OLED display installed in centre of main guages. (@isak - I have sent you an email recently regarding this compnent failing - everything is working i.e. I can engage forwards, reverse etc but as OLED has stopped working (only after about 6 uses) I can't tell what mode I'm in, state of charge or braking status so your advise would be useful).
    Installation almost complete but still needs final paintwork, interior touches, windscreen etc before i can use properly. Not sure I'f I/m going to bother with roof - it's a fine weather car anyway.
      We'll send you a new OLED. Awesome build! 🙂
      • S Offline
        S Offline
        steveo
        @isak Thanks for that Isak. When can I expect it to arrive? Awfully hard to proceed not knowing what’s going on. Please advise.
        • S Offline
          S Offline
          steveo
          @isak - sorry to push but where are you with sending the replacement OLED display? Please advise.
            Sorry your email response got lost we will send it next week
            • S Offline
              S Offline
              steveo
              Hi @isak. Has the replacement left you yet? If so, do you have a tracking number available? Please advise.
              • S Offline
                S Offline
                steveo
                @isak - another week goes by. Please advise on status of replacement display.
                  wrote last edited by
                  #8
                  We have sent your display a while a go you should have received it by now!
                  • S Offline
                    S Offline
                    steveo
                    #9
                    All sorted thank you @isak
