  3. 1962 Chevrolet Corvair Van
15 Posts 2 Posters 1.4k Views 1 Watching
  • T Offline
    T Offline
    trevorb24
    wrote on last edited by trevorb24
    My 1962 Corvair Van in the process of conversion as my university capstone project.
    • T Offline
      T Offline
      trevorb24
      Donor car is a 2015 Nissan Leaf, shown above before and after removing the motor and drivetrain stack. Final design will use the original Corvair transaxle and forgo the Leaf differential.
      • T Offline
        T Offline
        trevorb24
        • T Offline
          T Offline
          trevorb24
          First steps of making the adapter plate were done in PLA on a PRUSAXL 3D printer.
          • T Offline
            T Offline
            trevorb24
            • T Offline
              T Offline
              trevorb24
              Adapter plate prototype mounted to the Corvair bell housing and together with the Leaf motor...fitment looks good.
              • T Offline
                T Offline
                trevorb24
                • T Offline
                  T Offline
                  trevorb24
                  Stock loaded up in a CNC mill to machine the adapter
                  • T Offline
                    T Offline
                    trevorb24
                    #9
                    • T Offline
                      T Offline
                      trevorb24
                      In three different setups the profiling, drilling, pocket milling, and tapping for both sides was complete. After machining, two 10mm locator pins were pressed into circular pockets made in the plate. These are the pins that will fit into the Leaf motor face. Similarly, pockets were milled on the Corvair side to make a transition fit with the locator pins in the bell housing.
                      • C Offline
                        C Offline
                        colincotton
                        Very nice!
                        • T Offline
                          T Offline
                          trevorb24
                          wrote last edited by
                          #12
                          We used a pre-machined EM57 coupler and combined it with the cut out center of the Corvair's clutch to create a direct drive connection between the motor and the original transmission input shaft.
                          • T Offline
                            T Offline
                            trevorb24
                            #13
                            Turning down the clutch center.
                            • T Offline
                              T Offline
                              trevorb24
                              #14
                              Turning down the spline coupler.
                              • T Offline
                                T Offline
                                trevorb24
                                #15
                                We then pressed the two ends together and welded along the seam.
